New nonlinear CPRNG based on tent and logistic maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
This paper is devoted to the design of new chaotic Pseudo Random Number Generator (CPRNG). Exploring several topologies of network of 1-D coupled chaotic mapping, we focus first on two dimensional networks. Two coupled maps are studied: TTL^{RC} non-alternate, and TTL^{SC} alternate. The primary idea of the novel maps has been based on an original coupling of the tent and logistic maps to achieve excellent random properties and homogeneous /uniform/ density in the phase plane, thus guaranteeing maximum security when used for chaos base cryptography. In this aim a new nonlinear CPRNG: MTTL_{2}^{SC} is proposed. In addition, we explore higher dimension and the proposed ring coupling with injection mechanism enables us to achieve the strongest security requirements.
book.pdf (3.7 Mo) Télécharger le fichier
hal-01170134 , version 1 (04-07-2015)
Oleg Garasym, Ina Taralova, René Lozi. New nonlinear CPRNG based on tent and logistic maps. Jinhu Lü, Xinghuo Yu, Guanrong Chen, Wenwu Yu. Complex Systems and Networks — Dynamics, Controls and Applications, Springer, pp.107-130, 2015, Springer: Complexity, 978-3-662-47823-3. ⟨10.1007/978-3-662-47824-0⟩. ⟨hal-01170134⟩
398 Consultations
485 Téléchargements
