Design of a Robust Observer-Based FDI Scheme For a Class of Switched Systems Subject to Sensor Faults - Archive ouverte HAL Access content directly
Conference Papers Year :
This paper concerns the Fault Detection andIsolation (FDI) problem for a class of Switched Linear Systems(SLS) subject to sensor faults and unknown boundeddisturbances. The main work is based on the design of ageneralized switched observer scheme. The FDI problems havebeen solved by using a robust control techniques. A suitabletrade-off between the robustness to disturbances and thesensitivity to sensor faults was obtained. The main results arereformulated by using Linear Matrix Inequality (LMI)formulation. An example is included to illustrate the efficiency ofthe proposed approach.
Not file
Dates and versions
hal-01170484 , version 1 (01-07-2015)
Identifiers
  • HAL Id : hal-01170484 , version 1
Cite
Djamel Eddine Chouaib Belkhiat, Seif Chouaba, Hassen Fourati, Dalel Jabri. Design of a Robust Observer-Based FDI Scheme For a Class of Switched Systems Subject to Sensor Faults. CEIT 2015 - International Conference on Control, Engineering and Information Technology, IEEE, May 2015, Telemcen, Algeria. ⟨hal-01170484⟩
201 View
0 Download
Share
