Stochastic thermodynamics in the quantum regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Cyril Elouard
Alexia Auffèves
  • Fonction : Auteur
  • PersonId : 926695
Maxime Clusel
This article introduces a stochastic thermodynamics for driven out-of-equilibrium open quantum systems. A stochastic Schrodinger equation allows to construct quantum trajectories describing the dynamics of the system state vector in presence of an environment. Thermodynamic quantities are then defined at the single quantum trajectory level. We thereby identify coherent contributions, without classical counterparts, leading to quantum fluctuations of thermodynamic quantities. This formalism eventually leads to central fluctuation theorems for entropy, extending in the quantum regime results obtained in classical stochastic thermodynamics. The thermal imprint of coherences on a simple implementation of Jarzynski equality is investigated, opening avenues for a thermodynamic approach to decoherence.
qsthermo.pdf (1.57 Mo) Télécharger le fichier
hal-01170581 , version 1 (01-07-2015)
Cyril Elouard, Alexia Auffèves, Maxime Clusel. Stochastic thermodynamics in the quantum regime. 2015. ⟨hal-01170581⟩
315 Consultations
557 Téléchargements
