Hierarchical and combinatorial structures conceptual control: UDC v. Bilindex
Control conceptual en estructuras jerárquicas y combinatorias: CDU v. Bilindex
Contrôle conceptuel en structures hiérarchiques et combinatoires: CDU v. Bilindex
Index
Solidity of the indexation system and reference system.
Theories of proximity, the ratio between the terms and the subject indexing.
Custom subject indexation related to the task of retrieving information.
Definitions.
The pros and the cons.
Some data regarding the use.
Definition of documentary specificity.
Compared documentary specificity: CDU vs. Bilindex.
Other research directions concerning the relevant aspects inventoried in the present contribution.
Purposely constructing an indexing system likely to be mechanizable, Dr Mortimer Taube and Associates have driven a proposal forward (in 1957) to elaborate a dictionary of associations between words, of great value for both literature and operational research. These authors considered the outcome reported by an operational research worker, during the Second World War, regarding the value for aircraft batteries. He expressed that even if they have failed to eliminate enemy aircraft, it remained sufficient to reduce the likelihood them to sink the merchant ships. The reasons advanced by the authors alluded to the fact that the result might just as well be obtained by means of a dictionary of mechanized associations of words, that included "properly indexed and linked relevant information", in such a way as to facilitate an automated result from the combination of bombing accuracy and the fitting-out of a ship. Today SMART, a system research project based on a computer with word processors, confirms exactly the principles on which computerized dictionaries of word associations are built.
Índice
Solidez del sistema de indización y sistema de referencias.
Teoría de proximidad, relación entre términos e indización temática.
La operación de indización de materia respecto de la recuperación de la información.
Definiciones.
Ventajas y desventajas.
Algunos datos de uso.
Definición de especificidad documental.
Especificidad documental comparada: CDU v. Bilindex.
Otras líneas de investigación referidas a los aspectos expuestos en la presente contribución.
Con la saludable intención de construir un sistema de indización susceptible de mecanización, el Dr. Mortimer Taube y Asociados avanzaron en 1957 una propuesta de elaboración de un diccionario de asociaciones de gran valor tanto para la búsqueda de literatura como en lo relativo a la investigación de operaciones. Estos autores opinaban que el resultado apuntado por un trabajador en investigación de operaciones, durante la II Guerra Mundial, de que aún cuando no abatieran los aviones enemigos, las baterías antiaéreas seguían siendo valiosas dado que hacían disminuir la precisión de los aviones enemigos lo suficiente como para reducir la probabilidad de que echaran a pique navíos mercantes, también se obtendría por medio de un diccionario de asociaciones mecanizado, en el que "la información relevante se presentara adecuadamente indexada o asociada", de modo tal que la asociación de precisión bombardeo con armamento de los navíos produjera un resultado automático. En nuestros días el SMART, un proyecto de investigación de sistemas basado en ordenador que utiliza un procesado automático del texto, confirma lo bien sentado de los postulados sobre los que se construyen los diccionarios de carácter asociativo.
Index
Solidité du système d'indexation et système de références.
Théorie de proximité, rapport entre termes et indéxation thématique.
L'opération d'indéxation matière face à la récupération de l'information.
Définitions.
Avantages et inconvénients.
Quelques données d'usage.
Définition de la spécificité documentaire.
Spécificité documentaire comparée: CDU vs. Bilindex.
D'autres voies de recherche concernant les aspects recensés dans la présente contribution.
Avec l'intention bien arrêtée de construire un système d'indexation susceptible de mécanisation, le Dr Mortimer Taube et associés mettent en avant, en 1957, une proposition d'élaboration d'un Dictionnaire des associations des mots d'une grande valeur tant pour la recherche de littérature comme en ce qui concerne à la recherche opérationnelle. Ces auteurs ont estimé que le résultat notifié par un travailleur en recherche opérationnelle, pendant la Seconde Guerre mondiale, concernant la valeur des batteries antiaériennes (même ne parvenant pas à éliminer les avions ennemis, elle restait suffisante pour réduire la probabilité qu'il fissent couler les navires marchands), pouvait tout aussi bien être obtenu au moyen d'un dictionnaire des associations mécanisées, où "l'information rélévante soit présentée correctement classée ou associée", de telle façon que l'association de la précision du bombardement avec l'armement des navires devait aboutir à un résultat automatisable. Dès nos jours SMART, un projet de recherche de systèmes basé sur ordinateur à l'aide d'un traitement de texte, confirme tout à fait les principes sur lesquels se construisent les dictionnaires à caractère associatif.
