Name That Graph or the need to provide a model and syntax extension to specify the provenance of RDF graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When querying or reasoning on metadata from the semantic web, the source of this metadata as well as a number of other characteristics (date, trust, etc.) can be of great importance. While the SPARQL query language provides a keyword to match patterns against named graphs, the RDF data model focuses on expressing triples. In many cases it is interesting to augment these RDF triples with the notion of a provenance for each triple (or set of triples), typically an IRI specifying their real (e.g. author) or virtual origin (e.g. inference engine and entailment regime). This position paper extends on a member submission from INRIA (RDF/XML Source Declaration [1]) expressing the importance for us to provide a standard mechanism in RDF to name graphs. It proposes and discusses an RDF/XML syntax extension providing an attribute to specify the provenance of triples in an RDF/XML representation.
Name That Graph_3.pdf (548.5 Ko) Télécharger le fichier
hal-01170906 , version 1 (02-07-2015)
  • HAL Id : hal-01170906 , version 1
Fabien Gandon, Olivier Corby. Name That Graph or the need to provide a model and syntax extension to specify the provenance of RDF graphs. W3C Workshop — RDF Next Steps, W3C, Jun 2010, Palo Alto, United States. ⟨hal-01170906⟩
257 Consultations
59 Téléchargements
