Algorithms for Nonnegative Matrix Factorization with the ??-Divergence, Neural Computation, vol.11, issue.9, pp.2421-2456, 2011. ,
DOI : 10.1109/TASL.2009.2034186
Non-negative dynamical system with application to speech and audio, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.3158-3162, 2013. ,
DOI : 10.1109/ICASSP.2013.6638240
Multiple kernel learning algorithms, Journal of Machine Learning Research, vol.12, pp.2211-2268, 2011. ,
A comparative study on sparsity penalties for NMF-based speech separation: Beyond LP-norms, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.858-862, 2013. ,
DOI : 10.1109/ICASSP.2013.6637770
Sparse NMF ? half-baked or well done?, 2015. ,
Algorithms for non-negative matrix factorization, Advances in Neural Information Processing Systems (NIPS), pp.556-562 ,
Itakura-Saito nonnegative matrix factorization with group sparsity, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2011. ,
DOI : 10.1109/ICASSP.2011.5946318
A multimodal real-time mri articulatory corpus for speech research, pp.837-840, 2011. ,
A Survey on Transfer Learning, IEEE Transactions on Knowledge and Data Engineering, vol.22, issue.10, 2010. ,
DOI : 10.1109/TKDE.2009.191
Automatic Data-Driven Learning of Articulatory Primitives from Real-Time MRI Data Using Convolutive NMF with Sparseness Constraints, pp.61-64, 2011. ,
Probabilistic Factorization of Non-negative Data with Entropic Co-occurrence Constraints, ICA '09: Proc. of the 8th Int. Conf. on Independent Component Analysis and Signal Separation, 2009. ,
DOI : 10.1016/S0167-6393(00)00035-2
Non-negative Matrix Factor Deconvolution; Extraction of Multiple Sound Sources from Monophonic Inputs, pp.494-499, 2004. ,
DOI : 10.1007/978-3-540-30110-3_63
A multi-channel/multi-speaker articulatory database for continuous speech recognition research, Phonus, vol.5, pp.1-13, 2000. ,
Generalised coupled tensor factorisation, p.NIPS, 2011. ,
