Social Objects Description and Recommendation in Multidimensional Social Networks: OCSO Ontology and Semantic Spreading Activation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Two strong tendencies in social networks today are their growing multidimensionality and the key role of social objects around which they crystallize. We define OCSO as semantic web schema to describe finely these social objects and their afferent social activity. Then we defend the use of spreading activation algorithms to perform complex recommendation in multidimensional social networks. A possible approach to what we call semantic spreading activation is introduced in order to exploit, among others, the OCSO model.
Final Marie and al. Social object recommendation in multidimensional social network.pdf (514.41 Ko) Télécharger le fichier
hal-01171007 , version 1 (02-07-2015)
Nicolas Marie, Fabien Gandon. Social Objects Description and Recommendation in Multidimensional Social Networks: OCSO Ontology and Semantic Spreading Activation. 1st International Workshop on Social Object Networks (SocialObjects 2011), Oct 2011, Boston, United States. ⟨10.1109/PASSAT/SocialCom.2011.242⟩. ⟨hal-01171007⟩
563 Consultations
322 Téléchargements
