Adaptive kernel estimation of the baseline function in the Cox model, with high-dimensional covariates
The aim of this article is to propose a novel kernel estimator of the baseline function in a general high-dimensional Cox model, for which we derive non-asymptotic rates of convergence. To construct our estimator, we first estimate the regression parameter in the Cox model via a Lasso procedure. We then plug this estimator into the classical kernel estimator of the baseline function, obtained by smoothing the so-called Breslow estimator of the cumulative baseline function. We propose and study an adaptive procedure for selecting the bandwidth, in the spirit of Gold-enshluger and Lepski (2011). We state non-asymptotic oracle inequalities for the final estimator, which reveal the reduction of the rates of convergence when the dimension of the covariates grows.
KernelEstimation_Guilloux_Lemler_Taupin.pdf (701.51 Ko)
Télécharger le fichier
Supp_Mat_Guilloux_Lemler_Taupin.pdf (351.67 Ko)
