Audio declipping via nonnegative matrix factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Audio inpainting and audio declipping are important problems in audio signal processing, which are encountered in various practical applications. A number of approaches has been proposed in the literature to address these problems, most successful of which are based on sparsity of the audio signals in certain dictionary representations. Non-negative matrix factorization (NMF) is another powerful tool that has been successfully used in applications such as audio source separation. In this paper we propose a new algorithm that makes use of a low rank NMF model to perform audio inpainting and declipping. In addition to utilizing for the first time the NMF model to perform audio inpainting in presence of arbitrary losses in time domain, the proposed approach also introduces a novel way to enforce additional constraints on the signal magnitude in order to improve the performance in declipping applications. The proposed approach is shown to have a comparable performance with the state of the art dictionary based methods while providing a number of advantages.
waspaa15a.pdf (118.48 Ko) Télécharger le fichier
hal-01171813 , version 1 (08-07-2015)
  • HAL Id : hal-01171813 , version 1
Cagdas Bilen, Alexey Ozerov, Patrick Pérez. Audio declipping via nonnegative matrix factorization. IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, Oct 2015, New Paltz, NY, United States. ⟨hal-01171813⟩
Collections
ANR
168 Consultations
764 Téléchargements
