FROM BOSONIC GRAND-CANONICAL ENSEMBLES TO NONLINEAR GIBBS MEASURES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
In a recent paper, in collaboration with Mathieu Lewin and Phan Thành Nam, we showed that nonlinear Gibbs measures based on Gross-Pitaevskii like functionals could be derived from many-body quantum mechanics, in a mean-field limit. This text summarizes these findings. It focuses on the simplest, but most physically relevant, case we could treat so far, namely that of the defocusing cubic NLS functional on a 1D interval. The measure obtained in the limit, which (almost) lives over H^{1/2} , has been previously shown to be invariant under the NLS flow by Bourgain.
Texte_X-EDP_Jun15.pdf (230.3 Ko) Télécharger le fichier
hal-01171867 , version 1 (06-07-2015)
Nicolas Rougerie. FROM BOSONIC GRAND-CANONICAL ENSEMBLES TO NONLINEAR GIBBS MEASURES. 2015. ⟨hal-01171867⟩
285 Consultations
123 Téléchargements
