New interface
Journal articles
Natural Language Interaction with the Web of Data by Mining its Textual Side
Elena Cabrio 1, 2 Julien Cojan 1, 2 Alessio Palmero Aprosio 3 Fabien Gandon 1, 2
1 WIMMICS - Web-Instrumented Man-Machine Interactions, Communities and Semantics
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SPARKS - Scalable and Pervasive softwARe and Knowledge Systems
Abstract : The Semantic Web is an extension of the classical web. The data and schemas it adds coexist with the documents that were already linked and available. This not only allows interoperability, reusability and potentially unforeseen applications of opened data, but it also creates a unique situation of availability on the web of huge collections of the same pieces of information available at the same time as text and as structured data. An interesting example is the couple Wikipedia-DBpedia: exploiting these interlinked structured and unstructured data sources in parallel can offer a great potential for both Natural Language Processing and Semantic Web applications. Starting from these observations, this paper addresses the problem of enhancing interactions between non-expert users and data available on the Web. In particular, we present QAKiS, a system for open domain Question Answering over linked data, that addresses the problem of question interpretation as a relation-based match, where fragments of the question are matched to binary relations of the triple store, using relational textual patterns automatically collected. In the current version, the relational patterns are automatically extracted from Wikipedia, while DBpedia is the data set to be queried using a natural language interface.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01171879
Contributor : Elena Cabrio Connect in order to contact the contributor
Submitted on : Wednesday, July 15, 2015 - 11:01:13 AM
Last modification on : Friday, August 5, 2022 - 3:50:52 AM
Identifiers
  • HAL Id : hal-01171879, version 1
Citation
Elena Cabrio, Julien Cojan, Alessio Palmero Aprosio, Fabien Gandon. Natural Language Interaction with the Web of Data by Mining its Textual Side. Intelligenza Artificiale, 2012, Special Issue on Natural Language Processing in the Web Era, pp.137-154. ⟨hal-01171879⟩
Share
Metrics
Record views
239
