The mechanisms of plaster drying - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Materials Science Année : 2015
We show that the drying rate of plaster pastes is significantly lower than that expected for a pure liquid evaporating from a simple homogeneous porous medium. This effect is enhanced by the air flow velocity and the initial solid/water ratio. Further tests under various conditions and with the help of additional techniques (MRI, ESEM, Microtomography) for measuring the drying rate and local characteristics (water content, porosity) prove that this effect is due to the crystallization of gypsum ions below the sample free surface, which creates a dry region and decreases the drying rate by increasing the length of the path the vapor has to follow before reaching the free surface.
Article-141.pdf (2.92 Mo) Télécharger le fichier
hal-01172479 , version 1 (07-07-2015)
Mamadou Diaga Seck, M van Landeghem, P Faure, Stéphane Rodts, R Combes, et al.. The mechanisms of plaster drying. Journal of Materials Science, 2015, 50 (6), pp.2491-2501. ⟨10.1007/s10853-014-8807-x⟩. ⟨hal-01172479⟩
457 Consultations
3256 Téléchargements
