First order Mean Field Games with density constraints: Pressure equals Price - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
In this paper we study Mean Field Game systems under density constraints as optimality conditions of two optimization problems in duality. A weak solution of the system contains an extra term, an additional price imposed on the saturated zones. We show that this price corresponds to the pressure field from the models of incompressible Euler's equations à la Brenier. By this observation we manage to obtain a minimal regularity, which allows to write optimality conditions at the level of single agent trajectories and to define a weak notion of Nash equilibrium for our model.
20150706_carmessan_final.pdf (403.13 Ko) Télécharger le fichier
hal-01173947 , version 1 (07-07-2015)
hal-01173947 , version 2 (06-12-2016)
Pierre Cardaliaguet, Alpár Richárd Mészáros, Filippo Santambrogio. First order Mean Field Games with density constraints: Pressure equals Price. 2015. ⟨hal-01173947v1⟩
247 Consultations
153 Téléchargements
