Adjustments to Zatsiorsky-Seluyanov's segment inertia parameters, Journal of Biomechanics, vol.29, issue.9, pp.1223-1230, 1996. ,
DOI : 10.1016/0021-9290(95)00178-6
Adjustments to McConville et al. and Young et al. body segment inertial parameters, Journal of Biomechanics, vol.40, issue.3, pp.543-553, 2007. ,
DOI : 10.1016/j.jbiomech.2006.02.013
A simple method to calibrate kinematical invariants: application to overhead throwing, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01150814
The effect of segment parameter error on gait analysis results, Gait & Posture, vol.9, issue.3, pp.173-183, 1999. ,
DOI : 10.1016/S0966-6362(99)00011-9
Influence of body segments??? parameters estimation models on inverse dynamics solutions during gait, Journal of Biomechanics, vol.39, issue.8, pp.1531-1536, 2006. ,
DOI : 10.1016/j.jbiomech.2005.04.014
URL : https://hal.archives-ouvertes.fr/hal-00091846
Are Patient-Specific Joint and Inertial Parameters Necessary for Accurate Inverse Dynamics Analyses of Gait?, IEEE Transactions on Biomedical Engineering, vol.54, issue.5, pp.782-793, 2007. ,
DOI : 10.1109/TBME.2006.889187
The effect of perturbing body segment parameters on calculated joint moments and muscle forces during gait, Journal of Biomechanics, vol.47, issue.2, pp.596-601, 2014. ,
DOI : 10.1016/j.jbiomech.2013.11.002
Biomechanics and motor control of human movement, 1990. ,
DOI : 10.1002/9780470549148
