Numerical Simulations of Air???Sea Interaction under High Wind Conditions Using a Coupled Model: A Study of Hurricane Development, Monthly Weather Review, vol.128, issue.7, pp.2190-2210, 2000. ,
DOI : 10.1175/1520-0493(2000)128<2190:NSOASI>2.0.CO;2
Nesting Ocean Models, An Integrated View of Oceanography: Ocean Weather Forecasting in the 21st Century. Kluwer, 2006. ,
DOI : 10.1007/1-4020-4028-8_5
URL : https://hal.archives-ouvertes.fr/inria-00187576
Optimized Schwarz Waveform Relaxation Algorithms with Nonconforming Time Discretization for Coupling Convection-diffusion Problems with Discontinuous Coefficients, Lect. Notes Comput. Sci. Eng, vol.55, pp.267-274, 2007. ,
DOI : 10.1007/978-3-540-34469-8_31
URL : https://hal.archives-ouvertes.fr/inria-00187555
The NCAR CSM flux coupler, 1996. ,
Local multiplicative schwarz algorithms for steady and unsteady convection-diffusion equations, East-West J. Numer. Math, vol.6, pp.27-41, 1998. ,
Stability of algorithms for a two domain natural convection problem and observed model uncertainty, Computational Geosciences, vol.27, issue.43???44, pp.509-527, 2011. ,
DOI : 10.1007/s10596-010-9219-x
Diurnal Coupling in the Tropical Oceans of CCSM3, Journal of Climate, vol.19, issue.11, pp.2347-2365, 2006. ,
DOI : 10.1175/JCLI3739.1
Schwarz methods over the course of time, Electron. Trans. Numer. Anal, vol.31, pp.228-255, 2008. ,
Stability analysis of numerical interface conditions in fluid-structure thermal analysis, International Journal for Numerical Methods in Fluids, vol.116, issue.4, pp.421-436, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19970830)25:4<421::AID-FLD557>3.0.CO;2-J
Multiphysics simulations, The International Journal of High Performance Computing Applications, vol.67, issue.1, pp.5-83, 2013. ,
DOI : 10.1007/978-3-642-23099-8
URL : http://mediatum.ub.tum.de/doc/1308038/document.pdf
Surface Fluxes for Practitioners of Global Ocean Data Assimilation, An Integrated View of Oceanography: Ocean Weather Forecasting in the 21st Century. Kluwer, 2006. ,
DOI : 10.1007/1-4020-4028-8_9
Optimal Control of the Convergence Rate of Schwarz Waveform Relaxation Algorithms, Lecture Notes in Computational Science and Engineering, vol.91, pp.599-606, 2013. ,
DOI : 10.1007/978-3-642-35275-1_71
Toward an optimized global-in-time Schwarz algorithm for diffusion equations with discontinuous and spatially variable coefficients, part 1 : the constant coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.148-169, 2013. ,
Toward an optimized global-in-time Schwarz algorithm for diffusion equations with discontinuous and spatially variable coefficients, part 2 : the variable coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.170-186, 2013. ,
Sensitivity of ocean-atmosphere coupled models to the coupling method : example of tropical cyclone Erica, 2014. ,
Mathematical theory for the coupled atmosphere-ocean models, J. Math. Pures Appl, vol.74, pp.105-163, 1995. ,
A Realistic Model of the Wind-Induced Ekman Boundary Layer, Journal of Physical Oceanography, vol.7, issue.2, pp.248-255, 1977. ,
DOI : 10.1175/1520-0485(1977)007<0248:ARMOTW>2.0.CO;2
Numerical Simulation of Air???Sea Coupling during Coastal Upwelling, Journal of Physical Oceanography, vol.37, issue.8, pp.2081-2093, 2007. ,
DOI : 10.1175/JPO3104.1
