Studying white matter tractography reproducibility through connectivity matrices
Diffusion-weighted imaging is often used as a starting point for in vivo white matter (wm) connectivity to reconstruct potential wm pathways
between brain areas. In this study, we investigate the reproducibility of the connectivity matrix, resulting from different tractography parameters. We vary the number of streamlines used to construct the matrix in cortical to cortical connectivity and analyze its effects. We also compare the effect of probabilistic and deterministic local streamline tractography algorithms, seeding both from the wm and from wm-grey matter interface.
Imagerie médicale
