New interface
Conference papers
Dependency length minimisation effects in short spans: a large-scale analysis of adjective placement in complex noun phrases
Abstract : It has been extensively observed that languages minimise the distance between two related words. Dependency length minimisation effects are explained as a means to reduce memory load and for effective communication. In this paper, we ask whether they hold in typically short spans, such as noun phrases, which could be thought of being less subject to efficiency pressure. We demonstrate that minimisation does occur in short spans, but also that it is a complex effect: it is not only the length of the dependency that is at stake, but also the effect of the surrounding dependencies.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01174617
Contributor : Benoit Crabbe Connect in order to contact the contributor
Submitted on : Thursday, July 9, 2015 - 1:37:13 PM
Last modification on : Tuesday, October 25, 2022 - 4:19:40 PM
Identifiers
  • HAL Id : hal-01174617, version 1
Collections
Citation
Kristina Gulordava, Paola Merlo, Benoît Crabbé. Dependency length minimisation effects in short spans: a large-scale analysis of adjective placement in complex noun phrases. ACL 2015 - the 53rd annual meeting of the Association for Computational Linguistics, Jul 2015, Beijing, China. ⟨hal-01174617⟩
Share
Metrics
Record views
115
