Query-Oriented Summarization of RDF Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Resource Description Framework (RDF) is the W3C's graph data model for Semantic Web applications. We study the problem of RDF graph summarization: given an input RDF graph G, find an RDF graph G' which summarizes G as accurately as possible, while being possibly orders of magnitude smaller than the original graph. Our summaries are aimed as a help for query formulation and optimization; in particular, querying a summary of a graph should reflect whether the query has some answers against this graph. We introduce two summaries: a baseline which is compact and simple and satisfies certain accuracy and representativeness properties, but may oversimplify the RDF graph, and a refined one which trades some of these properties for more accuracy in representing the structure. The demonstration will allow the audience to compute such summaries out of a large variety of datasets, and explore their usage for data exploration and query optimization. The demonstration will also be presented in BDA 2015; its main ideas appear in BICOD 2015.
SummaryDemoBDA.pdf (323.92 Ko) Télécharger le fichier
hal-01176301 , version 1 (15-07-2015)
  • HAL Id : hal-01176301 , version 1
Šejla Čebirić, François Goasdoué, Ioana Manolescu. Query-Oriented Summarization of RDF Graphs. BDA (Bases de Données Avancées), Sep 2015, Île de Porquerolles, France. ⟨hal-01176301⟩
339 Consultations
409 Téléchargements
