The Ideal View on Rackoff's Coverability Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rackoff's small witness property for the coverability problem is the standard means to prove tight upper bounds in vector addition systems (VAS) and many extensions. We show how to derive the same bounds directly on the computations of the VAS instantiation of the generic backward coverability algorithm. This relies on a dual view of the algorithm using ideal decompositions of downwards-closed sets, which exhibits a key structural invariant in the VAS case. The same reasoning readily generalises to several VAS extensions.
lncs.pdf (388.67 Ko) Télécharger le fichier
hal-01176755 , version 1 (15-07-2015)
hal-01176755 , version 2 (02-02-2016)
hal-01176755 , version 3 (21-06-2017)
Copyright (Tous droits réservés)
Ranko Lazić, Sylvain Schmitz. The Ideal View on Rackoff's Coverability Technique. RP 2015 - 9th International Workshop on Reachability Problems, Sep 2015, Warsaw, Poland. pp.1--13, ⟨10.1007/978-3-319-24537-9_8⟩. ⟨hal-01176755v1⟩
482 Consultations
523 Téléchargements
