Sensitivity measures,anova-like Techniques and the use of bootstrap, Journal of Statistical Computation and Simulation, vol.2, issue.2, pp.99-120, 1997. ,
DOI : 10.1142/S0129183195000204
Accurate and efficient modelling of high temperature non-equilibrium air flows, 2001. ,
Uncertainty quantification of limit-cycle oscillations, Journal of Computational Physics, vol.217, issue.1, pp.217-247, 2006. ,
DOI : 10.1016/j.jcp.2006.03.038
Efficient computation of global sensitivity indices using sparse polynomial chaos expansions, Reliability Engineering & System Safety, vol.95, issue.11, pp.1216-1229, 2010. ,
DOI : 10.1016/j.ress.2010.06.015
An adaptive algorithm to build up sparse polynomial chaos expansions for stochastic finite element analysis, Probabilistic Engineering Mechanics, vol.25, issue.2, pp.183-197, 2010. ,
DOI : 10.1016/j.probengmech.2009.10.003
Adaptive sparse polynomial chaos expansion based on least angle regression, Journal of Computational Physics, vol.230, issue.6, pp.2345-2367, 2011. ,
DOI : 10.1016/j.jcp.2010.12.021
A new uncertainty importance measure, Reliability Engineering & System Safety, vol.92, issue.6, pp.771-784, 2007. ,
DOI : 10.1016/j.ress.2006.04.015
Comparison of global sensitivity analysis techniques and importance measures in PSA, Reliability Engineering & System Safety, vol.79, issue.2, pp.175-185, 2003. ,
DOI : 10.1016/S0951-8320(02)00228-4
Advances in sensitivity analysis, Reliability Engineering & System Safety, vol.107, pp.1-2, 2012. ,
DOI : 10.1016/j.ress.2012.09.001
Uncertainty and Sensitivity Analysis of Thermochemical Modeling for Titan Atmospheric Entry, 37th AIAA Thermophysics Conference, 2004. ,
DOI : 10.2514/6.2004-2455
Distribution-based global sensitivity analysis in case of correlated input parameters using polynomial chaos expansions, 2011. ,
DOI : 10.1201/b11332-105
Polynomial Chaos Expansion with Latin Hypercube Sampling for Estimating Response Variability, AIAA Journal, vol.42, issue.6, pp.1191-1198, 2004. ,
DOI : 10.2514/1.2220
Hybrid Upwind Splitting Scheme by a Field-by-Field Decomposition, 1995. ,
Polynomial chaos expansion for sensitivity analysis, Reliability Engineering & System Safety, vol.94, issue.7, pp.1161-1172, 2009. ,
DOI : 10.1016/j.ress.2008.10.008
Multi-element probabilistic collocation method in high dimensions, Journal of Computational Physics, vol.229, issue.5, pp.1536-1557, 2010. ,
DOI : 10.1016/j.jcp.2009.10.043
On ANOVA expansions and strategies for choosing the anchor point, ISUMA'90, First International Symposium on Uncertainty Modeling and Analysis, pp.3274-3285, 1990. ,
DOI : 10.1016/j.amc.2010.08.061
Spectral Methods for Uncertainty Quantification, 2010. ,
A Stochastic Projection Method for Fluid Flow II. Random Process, Journal of Computational Physics, vol.181, issue.1, pp.9-44, 2002. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, Journal of Computational Physics, vol.32, issue.1, pp.101-136, 1979. ,
DOI : 10.1016/0021-9991(79)90145-1
Global Sensitivity Analysis for Systems with Independent and/or Correlated Inputs, The Journal of Physical Chemistry A, vol.114, issue.19, pp.1146022-1146054, 2010. ,
DOI : 10.1021/jp9096919
High Dimensional Model Representations . The journal of physical chemistry, A, vol.105, issue.33, 2001. ,
DOI : 10.1021/jp010450t
An adaptive high-dimensional stochastic model representation technique for the solution of stochastic partial differential equations, Journal of Computational Physics, vol.229, issue.10, pp.3884-3915, 2010. ,
DOI : 10.1016/j.jcp.2010.01.033
Galerkin methods for linear and nonlinear elliptic stochastic partial differential equations, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.12-161295, 2005. ,
Upwind difference schemes for hyperbolic systems of conservation laws, Mathematics of Computation, vol.38, issue.158, pp.339-374, 1982. ,
DOI : 10.1090/S0025-5718-1982-0645656-0
Chemical-Kinetic Parameters of Hyperbolic Earth Entry, Journal of Thermophysics and Heat Transfer, vol.15, issue.1, pp.76-90, 2001. ,
DOI : 10.2514/2.6582
General foundations of high-dimensional model representations, Journal of Mathematical Chemistry, vol.25, issue.2/3, pp.197-233, 1999. ,
DOI : 10.1023/A:1019188517934
Efficient input???output model representations, Computer Physics Communications, vol.117, issue.1-2, pp.11-20, 1999. ,
DOI : 10.1016/S0010-4655(98)00152-0
A polynomial dimensional decomposition for stochastic computing, International Journal for Numerical Methods in Engineering, vol.39, issue.4, pp.2091-2116, 2008. ,
DOI : 10.1002/nme.2394
Global sensitivity analysis by polynomial dimensional decomposition, Reliability Engineering & System Safety, vol.96, issue.7, pp.825-837, 2011. ,
DOI : 10.1016/j.ress.2011.03.002
Novel computational methods for high-dimensional stochastic sensitivity analysis, International Journal for Numerical Methods in Engineering, vol.66, issue.3, 2014. ,
DOI : 10.1002/nme.4659
ORTHOGONAL POLYNOMIAL EXPANSIONS FOR SOLVING RANDOM EIGENVALUE PROBLEMS, International Journal for Uncertainty Quantification, vol.1, issue.2, pp.163-187, 2011. ,
DOI : 10.1615/IntJUncertaintyQuantification.v1.i2.40
Variance based sensitivity analysis of model output. Design and estimator for the total sensitivity index, Computer Physics Communications, vol.181, issue.2, pp.259-270, 2010. ,
DOI : 10.1016/j.cpc.2009.09.018
Uniformly distributed sequences with an additional uniform property, USSR Computational Mathematics and Mathematical Physics, vol.16, issue.5, pp.236-242, 1976. ,
DOI : 10.1016/0041-5553(76)90154-3
On sensitivity estimation for nonlinear mathematical models, Matem. Mod, vol.2, issue.1, pp.112-118, 1990. ,
Global sensitivity indices for nonlinear mathematical models and their Monte Carlo estimates, Mathematics and Computers in Simulation, vol.55, issue.1-3, pp.271-280, 2001. ,
DOI : 10.1016/S0378-4754(00)00270-6
Global sensitivity analysis using polynomial chaos expansions, Reliability Engineering & System Safety, vol.93, issue.7, pp.964-979, 2008. ,
DOI : 10.1016/j.ress.2007.04.002
URL : https://hal.archives-ouvertes.fr/hal-01432217
Sensitivity analysis using anchored ANOVA expansion and high-order moments computation, International Journal for Numerical Methods in Engineering, vol.92, issue.6, pp.1-31, 2015. ,
DOI : 10.1002/nme.4856
URL : https://hal.archives-ouvertes.fr/hal-01086259
In-Flight Testing of Critical Technologies and Experimentation of Aerothermodynamic Phenomena, 16th AIAA/DLR/DGLR International Space Planes and Hypersonic Systems and Technologies Conference, 2009. ,
DOI : 10.2514/6.2009-7232
Bayesian-Based Method with Metamodels for Rebuilding Freestream Conditions in Atmospheric Entry Flows, AIAA Journal, vol.52, issue.10, pp.522190-2197, 2014. ,
DOI : 10.2514/1.J052831
URL : https://hal.archives-ouvertes.fr/hal-00936641
Uncertainty quantification for gassurface interaction in plasmatron, Specialists Meeting on Catalytic Gas Surface Interactions (AVT-199), 2012. ,
On the approximation error in high dimensional model representation, 2008 Winter Simulation Conference, pp.453-462, 2008. ,
DOI : 10.1109/WSC.2008.4736100
Recommended Collision Integrals for Transport Property Computations Part 1: Air Species, AIAA Journal, vol.43, issue.12, pp.2558-2564, 2005. ,
DOI : 10.2514/1.16713
The Wiener--Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
DOI : 10.1137/S1064827501387826
Modeling uncertainty in flow simulations via generalized polynomial chaos, Journal of Computational Physics, vol.187, issue.1, pp.137-167, 2003. ,
DOI : 10.1016/S0021-9991(03)00092-5
Extending a global sensitivity analysis technique to models with correlated parameters, Computational Statistics & Data Analysis, vol.51, issue.12, pp.5579-5590, 2007. ,
DOI : 10.1016/j.csda.2007.04.003
Uncertainty and sensitivity analysis for models with correlated parameters, Reliability Engineering & System Safety, vol.93, issue.10, pp.1563-1573, 2008. ,
DOI : 10.1016/j.ress.2007.06.003
Adaptive-sparse polynomial dimensional decomposition methods for high-dimensional stochastic computing, Computer Methods in Applied Mechanics and Engineering, vol.274, pp.56-83, 2014. ,
DOI : 10.1016/j.cma.2014.01.027
