Controlling impatience in cellular networks using QoE-aware radio resource allocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider in this paper an important Quality of Experience (QoE) indicator in cellular networks that is reneging of users due to impatience. We specifically consider a cell under heavy load conditions, modeled as a multiclass Processor Sharing system, and compute the reneging probability by using a fluid limit analysis. In order to enhance the user QoE, we propose a radio resource allocation control scheme that minimizes the global reneging rates. This control scheme is based on the $\alpha$-fair scheduling framework and adapts the scheduler parameter depending on the traffic load. While the proposed scheme is simple, our results show that it achieves important performance gains.
Fichier non déposé
hal-01179377 , version 1 (22-07-2015)
  • HAL Id : hal-01179377 , version 1
Salah Eddine Elayoubi, Christine Fricker, Fabrice Guillemin, Philippe Robert, Bruno Sericola. Controlling impatience in cellular networks using QoE-aware radio resource allocation. 27th ITC International Teletraffic Congress (ITC 27), Sep 2015, Ghent, Belgium. ⟨hal-01179377⟩
286 Consultations
0 Téléchargements
