Parallel fft algorithms on network-on-chips, In: Proceedings ITNG, 2008. ,
Constraint-based scheduling: applying constraint programming to scheduling problems, 2001. ,
DOI : 10.1007/978-1-4615-1479-4
URL : https://hal.archives-ouvertes.fr/inria-00123562
Measuring the Performance of Schedulability Tests, Real-Time Systems, vol.20, issue.1, pp.129-154, 2005. ,
DOI : 10.1007/s11241-005-0507-9
Predicate-aware, makespan-preserving software pipelining of scheduling tables, ACM Transactions on Architecture and Code Optimization, vol.11, issue.1, p.12, 2014. ,
DOI : 10.1145/2579676
URL : https://hal.archives-ouvertes.fr/hal-01095123
Optimal scheduling for two-processor systems, Acta informatica, vol.1, issue.3, pp.200-213, 1972. ,
SMT-based Task- and Network-level Static Schedule Generation for Time-Triggered Networked Systems, Proceedings of the 22nd International Conference on Real-Time Networks and Systems, RTNS '14, pp.45-45, 2014. ,
DOI : 10.1145/2659787.2659812
Complexity Results for Multiprocessor Scheduling under Resource Constraints, SIAM Journal on Computing, vol.4, issue.4, pp.397-411, 1975. ,
DOI : 10.1137/0204035
Optimization of static task and bus access schedules for time-triggered distributed embedded systems with model-checking, Design Automation Conference DAC '07, pp.294-299, 2007. ,
Synthesizing Cyber-Physical Architectural Models with Real-Time Constraints, Computer Aided Verification, pp.441-456, 2011. ,
DOI : 10.1109/32.637388
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.642.5037
-complete problems, Communications of the ACM, vol.57, issue.5, pp.98-107, 2014. ,
DOI : 10.1145/2594413.2594424
URL : https://hal.archives-ouvertes.fr/in2p3-00575330
Minimizing Task Preemptions and Migrations in Multiprocessor Optimal Real-Time Schedules, 2010 31st IEEE Real-Time Systems Symposium, pp.2010-2041, 2010. ,
DOI : 10.1109/RTSS.2010.22
A general constraint-centric scheduling framework for spatial architectures, Proceedings PLDI'13, pp.495-506, 2013. ,
DOI : 10.1145/2499370.2462163
Symmetry Breaking for Multi-criteria Mapping and Scheduling on Multicores, pp.228-242, 2013. ,
DOI : 10.1007/978-3-642-40229-6_16
Performance-effective and low-complexity task scheduling for heterogeneous computing. Parallel and Distributed Systems, IEEE Transactions on, vol.13, issue.3, pp.260-274, 2002. ,
