Semidefinite approximations of the polynomial abscissa - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2016
Given a univariate polynomial, its abscissa is the maximum real part of its roots. The abscissa arises naturally when controlling linear differential equations. As a function of the polynomial coefficients, the abscissa is Hölder continuous, and not locally Lipschitz in general, which is a source of numerical difficulties for designing and optimizing control laws. In this paper we propose simple approximations of the abscissa given by polynomials of fixed degree, and hence controlled complexity. Our approximations are computed by a hierarchy of finite-dimensional convex semidefinite programming problems. When their degree tends to infinity, the polynomial approximations converge in norm to the abcissa, either from above or from below.
abscissa.pdf (763.58 Ko) Télécharger le fichier
hal-01181623 , version 1 (30-07-2015)
Roxana Hess, Didier Henrion, Jean-Bernard Lasserre, Tien Son Pham. Semidefinite approximations of the polynomial abscissa. SIAM Journal on Control and Optimization, 2016, 54 (3), pp. 1633-1656. ⟨hal-01181623⟩
230 Consultations
135 Téléchargements
