Abstract : We present an evaluator for navigational XPath on Xml
streams with projection. The idea is to project away those parts of an
Xml stream that are irrelevant for evaluating a given XPath query. This
task is relevant for processing Xml streams in general since all Xml
standard languages are based on XPath. The best existing streaming
algorithm for navigational XPath queries runs nested word automata.
Therefore, we develop a projection algorithm for nested word automata,
for the first time to the best of our knowledge. It turns out that projection
can speed up the evaluation of navigational XPath queries on Xml
streams by a factor of 4 in average on the usual XPath benchmarks.
The extended version of the document is available in pdf here.
