Shared nearest neighbors match kernel for bird songs identification -LifeCLEF 2015 challenge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexis Joly
Julien Champ
Olivier Buisson
  • Fonction : Auteur
  • PersonId : 968716
This paper presents a new fine-grained audio classification technique designed and experimented in the context of the LifeCLEF 2015 bird species identification challenge. Inspired by recent works on fine-grained image classification, we introduce a new match kernel based on the shared nearest neighbors of the low level audio features extracted at the frame level. To make such strategy scalable to the tens of millions of MFCC features extracted from the tens of thousands audio recordings of the training set, we used high-dimensional hashing techniques coupled with an efficient approximate nearest neighbors search algorithm with controlled quality. Further improvements are obtained by (i) using a sliding window for the temporal pooling of the raw matches (ii) weighting each low level feature according to the semantic coherence of its nearest neighbors. Results show the effectiveness of the proposed technique which ranked 2nd among the 7 research groups participating to the LifeCLEF bird challenge.
ZENITH_BirdCLEF2015.pdf (473.77 Ko) Télécharger le fichier
hal-01182784 , version 1 (11-08-2015)
  • HAL Id : hal-01182784 , version 1
Alexis Joly, Valentin Leveau, Julien Champ, Olivier Buisson. Shared nearest neighbors match kernel for bird songs identification -LifeCLEF 2015 challenge. CLEF: Conference and Labs of the Evaluation Forum, Sep 2015, Toulouse, France. ⟨hal-01182784⟩
388 Consultations
201 Téléchargements
