The Kalman Laplace filter: a new deterministic algorithm for nonlinear Bayesian filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new nonlinear Bayesian filtering algorithm where the prediction step is performed like in the extended Kalman filter, and the update step is done thanks to the Laplace method for integral approximation. This algorithm is called the Kalman Laplace filter (KLF). The KLF provides a closed–form non–Gaussian approximation of the posterior density. The hidden state is estimated by the maximum a posteriori. We describe a way to alleviate the computation cost of this maximization, when the likelihood is a function of a vector whose dimension is smaller than the state space dimension. The KLF is tested on three simulated nonlinear filtering problems: target tracking with angle measurements, population dynamics monitoring, motion reconstruction by neural decoding. It exhibits a good performance, especially when the observation noise is small.
Fichier non déposé
hal-01183413 , version 1 (07-08-2015)
  • HAL Id : hal-01183413 , version 1
Paul Bui Quang, Christian Musso, François Le Gland. The Kalman Laplace filter: a new deterministic algorithm for nonlinear Bayesian filtering. Proceedings of the 18th International Conference on Information Fusion, Washington DC 2015, Jul 2015, Washington DC, United States. pp.1657--1663. ⟨hal-01183413⟩
341 Consultations
0 Téléchargements
