Other publications
Is audio signal processing still useful in the era of machine learning?
Emmanuel Vincent 1
1 MULTISPEECH - Speech Modeling for Facilitating Oral-Based Communication
Inria Nancy - Grand Est, LORIA - NLPKD - Department of Natural Language Processing & Knowledge Discovery
Abstract : Audio signal processing has long been the obvious approach to problems such as microphone array processing, active noise control, or speech enhancement. Yet, it is increasingly being challenged by black-box machine learning approaches based on, e.g., deep neural networks (DNN), which have already achieved superior results on certain tasks. In this talk, I will try to convince that machine learning approaches shouldn’t be disregarded, but that black boxes won’t solve these problems either. There is hence an opportunity for signal processing researchers to join forces with machine learning researchers and solve these problems together. I will provide examples of this multi-disciplinary approach for audio source separation and robust automatic speech recognition.
Document type :
Other publications
Complete list of metadata
https://hal.inria.fr/hal-01183506
Contributor : Emmanuel Vincent Connect in order to contact the contributor
Submitted on : Saturday, August 8, 2015 - 11:44:58 PM
Last modification on : Saturday, October 16, 2021 - 11:26:09 AM
Identifiers
  • HAL Id : hal-01183506, version 1
Collections
Citation
Emmanuel Vincent. Is audio signal processing still useful in the era of machine learning?. 2015. ⟨hal-01183506⟩
Share
Metrics
Les métriques sont temporairement indisponibles
