Entropic repulsion on a rarefied wall - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2003
We consider the motion of a discrete d-dimensional random surface interacting by exclusion with a rarefied wall. The dynamics is given by the serial harness process. We prove that the process delocalizes iff the mean number of visits to the set of sites where the wall is present by some random walk is infinite. In case where there is a delocalization, bounds on its speed are obtained.
dmAC0110.pdf (87.53 Ko) Télécharger le fichier
hal-01183946 , version 1 (12-08-2015)
L. R. G. Fontes, M. Vachkovskaia, A. Yambartsev. Entropic repulsion on a rarefied wall. Discrete Random Walks, DRW'03, 2003, Paris, France. pp.105-112, ⟨10.46298/dmtcs.3350⟩. ⟨hal-01183946⟩
Collections
TDS-MACS
153 Consultations
618 Téléchargements
