A repertoire for additive functionals of uniformly distributed m-ary search trees
Using recent results on singularity analysis for Hadamard products of generating functions, we obtain the limiting distributions for additive functionals on $m$-ary search trees on $n$ keys with toll sequence $(i) n^α$ with $α ≥ 0 (α =0$ and $α =1$ correspond roughly to the space requirement and total path length, respectively); $(ii) ln \binom{n} {m-1}$, which corresponds to the so-called shape functional; and $(iii) $$1$$_{n=m-1}$, which corresponds to the number of leaves.
