Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Distribution of inter-node distances in digital trees
Abstract : We investigate distances between pairs of nodes in digital trees (digital search trees (DST), and tries). By analytic techniques, such as the Mellin Transform and poissonization, we describe a program to determine the moments of these distances. The program is illustrated on the mean and variance. One encounters delayed Mellin transform equations, which we solve by inspection. Interestingly, the unbiased case gives a bounded variance, whereas the biased case gives a variance growing with the number of keys. It is therefore possible in the biased case to show that an appropriately normalized version of the distance converges to a limit. The complexity of moment calculation increases substantially with each higher moment; A shortcut to the limit is needed via a method that avoids the computation of all moments. Toward this end, we utilize the contraction method to show that in biased digital search trees the distribution of a suitably normalized version of the distances approaches a limit that is the fixed-point solution (in the Wasserstein space) of a distributional equation. An explicit solution to the fixed-point equation is readily demonstrated to be Gaussian.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01184045
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Wednesday, August 12, 2015 - 3:52:53 PM
Last modification on : Thursday, April 15, 2021 - 6:04:01 PM
Long-term archiving on: : Friday, November 13, 2015 - 11:40:53 AM
File
dmAD0101.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Rafik Aguech, Nabil Lasmar, Hosam Mahmoud. Distribution of inter-node distances in digital trees. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.1-10, ⟨10.46298/dmtcs.3373⟩. ⟨hal-01184045⟩
Share
Metrics
Record views
69
Files downloads
417
