Conference papers
Application of data compression methods to hypothesis testing for ergodic and stationary processes
Abstract : We show that data compression methods (or universal codes) can be applied for hypotheses testing in a framework of classical mathematical statistics. Namely, we describe tests, which are based on data compression methods, for the three following problems: i) identity testing, ii) testing for independence and iii) testing of serial independence for time series. Applying our method of identity testing to pseudorandom number generators, we obtained experimental results which show that the suggested tests are quite efficient.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01184215
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Thursday, August 13, 2015 - 1:34:42 PM
Last modification on : Thursday, May 11, 2017 - 1:03:09 AM
Long-term archiving on: : Saturday, November 14, 2015 - 10:23:07 AM
File
dmAD0138.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Boris Ryabko, Jaakko Astola. Application of data compression methods to hypothesis testing for ergodic and stationary processes. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.399-408, ⟨10.46298/dmtcs.3380⟩. ⟨hal-01184215⟩
Share
Metrics
Record views
43
Files downloads
391
