The master ring problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We consider the $\textit{master ring problem (MRP)}$ which often arises in optical network design. Given a network which consists of a collection of interconnected rings $R_1, \ldots, R_K$, with $n_1, \ldots, n_K$ distinct nodes, respectively, we need to find an ordering of the nodes in the network that respects the ordering of every individual ring, if one exists. Our main result is an exact algorithm for MRP whose running time approaches $Q \cdot \prod_{k=1}^K (n_k/ \sqrt{2})$ for some polynomial $Q$, as the $n_k$ values become large. For the $\textit{ring clearance problem}$, a special case of practical interest, our algorithm achieves this running time for rings of $\textit{any}$ size $n_k \geq 2$. This yields the first nontrivial improvement, by factor of $(2 \sqrt{2})^K \approx (2.82)^K$, over the running time of the naive algorithm, which exhaustively enumerates all $\prod_{k=1}^K (2n_k)$ possible solutions.
dmAD0126.pdf (154.68 Ko) Télécharger le fichier
hal-01184218 , version 1 (13-08-2015)
Hadas Shachnai, Lisa Zhang. The master ring problem. 2005 International Conference on Analysis of Algorithms, 2005, Barcelona, Spain. pp.287-296, ⟨10.46298/dmtcs.3383⟩. ⟨hal-01184218⟩
Collections
TDS-MACS
36 Consultations
498 Téléchargements
