Approximate Boundary Conditions in Electromagnetics, Institution of Electrical Engineers, 1995. ,
Finite Element Analysis of Acoustic Scattering, 1998. ,
DOI : 10.1007/b98828
Surface Impedance Boundary Conditions: A Comprehensive Approach, 2010. ,
DOI : 10.1201/9781420044904
High-order boundary conditions and finite elements for infinite domains, Computer Methods in Applied Mechanics and Engineering, vol.143, issue.1-2, pp.1-2, 1997. ,
DOI : 10.1016/S0045-7825(96)01150-4
An analysis of Feng???s and other symmetric local absorbing boundary conditions, ESAIM: Mathematical Modelling and Numerical Analysis, vol.49, issue.1, pp.257-273, 2015. ,
DOI : 10.1051/m2an/2014029
On Generalized Ventcel's Type Boundary Conditions for Laplace Operator in a Bounded Domain, SIAM Journal on Mathematical Analysis, vol.42, issue.2, pp.931-945, 2010. ,
DOI : 10.1137/090756521
On High-Order FEM Applied to Canonical Scattering Problems in Plasmonics, Journal of Computational and Theoretical Nanoscience, vol.8, issue.8, pp.1-9, 2011. ,
DOI : 10.1166/jctn.2011.1851
Special finite elements for use with high-order boundary conditions, Computer Methods in Applied Mechanics and Engineering, vol.119, issue.3-4, pp.3-4, 1994. ,
DOI : 10.1016/0045-7825(94)90089-2
High-Order Nonreflecting Boundary Conditions without High-Order Derivatives, Journal of Computational Physics, vol.170, issue.2, pp.849-870, 2001. ,
DOI : 10.1006/jcph.2001.6766
High-order local non-reflecting boundary conditions: a review, Wave Motion, vol.39, issue.4, pp.319-326, 2004. ,
DOI : 10.1016/j.wavemoti.2003.12.004
Discontinuous Galerkin Finite Element Method for the Wave Equation, SIAM Journal on Numerical Analysis, vol.44, issue.6, pp.2408-2431, 2006. ,
DOI : 10.1137/05063194X
URL : https://hal.archives-ouvertes.fr/hal-01443184
C 0 Interior Penalty Methods for Fourth Order Elliptic Boundary Value Problems on Polygonal Domains, Journal of Scientific Computing, vol.44, issue.1-3, pp.22-23, 2005. ,
DOI : 10.1007/s10915-004-4135-7
Non-reflecting boundary conditions, Journal of Computational Physics, vol.94, issue.1, pp.1-29, 1991. ,
DOI : 10.1016/0021-9991(91)90135-8
Impedance boundary conditions for imperfectly conducting surfaces, Applied Scientific Research, Section B, vol.8, issue.1, pp.418-436, 1960. ,
DOI : 10.1007/BF02920074
Calculation of skin effect by perturbation method, Zh. Exp. Teor. Fiz, vol.10, pp.180-189, 1940. ,
On approximate boundary conditions for electromagnetic fields on the surface of highly conducting bodies, in: Research in the Propagation of Radio Waves, Academy of Sciences of the USSR, pp.5-12, 1948. ,
GENERALIZED IMPEDANCE BOUNDARY CONDITIONS FOR SCATTERING BY STRONGLY ABSORBING OBSTACLES: THE SCALAR CASE, Mathematical Models and Methods in Applied Sciences, vol.15, issue.08, pp.1273-1300, 2005. ,
DOI : 10.1142/S021820250500073X
URL : https://hal.archives-ouvertes.fr/hal-00743895
Surface Impedance Boundary Conditions in Terms of Various Formalisms, IEEE Transactions on Magnetics, vol.46, issue.9, pp.3617-3628, 2010. ,
DOI : 10.1109/TMAG.2010.2049363
Effective boundary conditions for acoustic and electromagnetic scattering in thin layers, 1993. ,
The Effect of a Thin Coating on the Scattering of a Time-Harmonic Wave for the Helmholtz Equation, SIAM Journal on Applied Mathematics, vol.56, issue.6, pp.1664-1693, 1996. ,
DOI : 10.1137/S0036139995281822
Asymptotics for steady-state voltage potentials in a bidimensional highly contrasted medium with thin layer, Mathematical Methods in the Applied Sciences, vol.34, issue.4, pp.443-479, 2008. ,
DOI : 10.1002/mma.923
URL : https://hal.archives-ouvertes.fr/inria-00334770
Generalized impedance boundary conditions for thin dielectric coatings with variable thickness, Wave Motion, vol.48, issue.7, pp.681-700, 2011. ,
DOI : 10.1016/j.wavemoti.2011.06.002
Thöns-Zueva, Impedance boundary conditions for acoustic time harmonic wave propagation in viscous gases, 2014. ,
A Unified Analysis of Transmission Conditions for Thin Conducting Sheets in the Time-Harmonic Eddy Current Model, SIAM Journal on Applied Mathematics, vol.73, issue.6, 1980. ,
DOI : 10.1137/120901398
Approximate models for wave propagation across thin periodic interfaces, Journal de Math??matiques Pures et Appliqu??es, vol.98, issue.1, pp.28-71, 2012. ,
DOI : 10.1016/j.matpur.2012.01.003
URL : https://hal.archives-ouvertes.fr/hal-00741614
Generalized boundary and transition conditions and the question of uniqueness, Radio Science, vol.4, issue.B, pp.929-934, 1992. ,
DOI : 10.1029/92RS01426
An Elliptic Collocation-Finite Element Method with Interior Penalties, SIAM Journal on Numerical Analysis, vol.15, issue.1, pp.152-161, 1978. ,
DOI : 10.1137/0715010
A Priori Error Estimates for Finite Element Methods Based on Discontinuous Approximation Spaces for Elliptic Problems, SIAM Journal on Numerical Analysis, vol.39, issue.3, pp.902-931, 2001. ,
DOI : 10.1137/S003614290037174X
Symmetric and Nonsymmetric Discontinuous Galerkin Methods for Reactive Transport in Porous Media, SIAM Journal on Numerical Analysis, vol.43, issue.1, pp.195-219, 2005. ,
DOI : 10.1137/S003614290241708X
Elliptic Boundary Value Problems in Domains with Point Singularities, Mathematical Surveys and Monographs, 1997. ,
DOI : 10.1090/surv/052
p-and hp-Finite Element Methods: Theory and Applications in Solid and Fluid Mechanics, 1998. ,
A new auxiliary variable formulation of high-order local radiation boundary conditions: corner compatibility conditions and extensions to first-order systems, Wave Motion, vol.39, issue.4, pp.327-338, 2004. ,
DOI : 10.1016/j.wavemoti.2003.12.007
High-order local absorbing conditions for the wave equation: Extensions and improvements, Journal of Computational Physics, vol.227, issue.6, pp.3322-3357, 2008. ,
DOI : 10.1016/j.jcp.2007.11.040
Acoustic and Electromagnetic Equations, Applied Mathematical Sciences, vol.144, 2001. ,
Boundary Conditions for the Numerical Solution of Elliptic Equations in Exterior Regions, SIAM Journal on Applied Mathematics, vol.42, issue.2, pp.430-451, 1982. ,
DOI : 10.1137/0142032
Bayliss???Turkel-like Radiation Conditions on Surfaces of Arbitrary Shape, Journal of Mathematical Analysis and Applications, vol.229, issue.1, pp.184-211, 1999. ,
DOI : 10.1006/jmaa.1998.6153
Three-dimensional approximate local DtN boundary conditions for prolate spheroid boundaries, Journal of Computational and Applied Mathematics, vol.234, issue.6, pp.1810-1816, 2010. ,
DOI : 10.1016/j.cam.2009.08.032
URL : https://hal.archives-ouvertes.fr/inria-00338506
Non-Reflecting Finite Element Schemes for Three-Dimensional Acoustic Waves, Journal of Computational Acoustics, vol.05, issue.01, pp.95-115, 1997. ,
DOI : 10.1142/S0218396X97000071
Computational methods for problems of acoustics with particular reference to exterior domains, 1988. ,
On the constants in hp-finite element trace inverse inequalities, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.25, pp.2765-2773, 2003. ,
DOI : 10.1016/S0045-7825(03)00294-9
Wavenumber Explicit Convergence Analysis for Galerkin Discretizations of the Helmholtz Equation, SIAM Journal on Numerical Analysis, vol.49, issue.3, pp.1210-1243, 2011. ,
DOI : 10.1137/090776202
Eigenvalue problems, pp.641-787, 1991. ,
DOI : 10.1016/S1570-8659(05)80042-0
An observation concerning Ritz-Galerkin methods with indefinite bilinear forms, Mathematics of Computation, vol.28, issue.128, pp.959-962, 1974. ,
DOI : 10.1090/S0025-5718-1974-0373326-0
The Mathematical Theory of Finite Element Methods, 1994. ,
The Finite Element Method for Elliptic Problems, Studies in Mathematics and its Applications, 1978. ,
Concepts???An Object-Oriented Software Package for Partial Differential Equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.36, issue.5, pp.937-951, 2002. ,
DOI : 10.1051/m2an:2002036
Computation of the band structure of two-dimensional photonic crystals with hp finite elements, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.13-14, pp.1249-1259, 2009. ,
DOI : 10.1016/j.cma.2008.06.009
URL : https://hal.archives-ouvertes.fr/hal-00974812
High-Resolution Mapping of Electron-Beam-Excited Plasmon Modes in Lithographically Defined Gold Nanostructures, Nano Letters, vol.11, issue.3, pp.1323-1330, 2011. ,
DOI : 10.1021/nl104410t
