Cyclo-static data flow, 1995 International Conference on Acoustics, Speech, and Signal Processing, pp.3255-3258, 1995. ,
DOI : 10.1109/ICASSP.1995.479579
Scheduling dynamic dataflow graphs with bounded memory using the token flow model, IEEE International Conference on Acoustics Speech and Signal Processing, 1993. ,
DOI : 10.1109/ICASSP.1993.319147
Counting solutions to linear and nonlinear constraints through Ehrhart polynomials: Application to analyze and transform scientic programs, ACM International Conference on Supercomputing (ICS'96), pp.278-285, 1996. ,
Automatic memory layout transformations to optimize spatial locality in parameterized loop nests, ACM SIGARCH Computer Architecture News, vol.28, issue.1, pp.11-19, 2000. ,
DOI : 10.1145/346023.346031
Scheduling and Automatic Parallelization, 2000. ,
DOI : 10.1007/978-1-4612-1362-8
URL : https://hal.archives-ouvertes.fr/hal-00856645
Z3: An efficient SMT solver Corresponding software: https://github, 14th International Conference on Tools and Algorithms for the Construction and Analysis of Systems (TACAS'08), pp.337-340, 2008. ,
Parametric integer programming, RAIRO - Operations Research, vol.22, issue.3, pp.243-268, 1988. ,
DOI : 10.1051/ro/1988220302431
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1007/BF01407931
Scalable and Structured Scheduling, International Journal of Parallel Programming, vol.28, issue.6, pp.459-487, 2006. ,
DOI : 10.1007/s10766-006-0011-4
The power of polynomials, 5th International Workshop on Polyhedral Compilation Techniques (IMPACT'15), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01094787
The polyhedral model, Encyclopedia of Parallel Programming, 2011. ,
SPDF: A schedulable parametric dataflow model of computations, Conference on Design, Automation and Test in Europe (DATE'12), pp.769-774, 2012. ,
Exploiting coarse-grained task, data, and pipeline parallelism in stream programs, 12th International Conference on Architectural Support for Programming Languages and Operating Systems (ASPLOS'06), pp.151-162, 2006. ,
Representing polynomials by positive linear functions on compact convex polyhedra, Pacific Journal of Mathematics, vol.132, issue.1, pp.35-63, 1988. ,
DOI : 10.2140/pjm.1988.132.35
The semantics of a simple language for parallel programming, IFIP'94, pp.471-475, 1974. ,
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
Compaan, Proceedings of the eighth international workshop on Hardware/software codesign , CODES '00, 2000. ,
DOI : 10.1145/334012.334015
Static Scheduling of Synchronous Data Flow Programs for Digital Signal Processing, IEEE Transactions on Computers, vol.36, issue.1, pp.24-25, 1987. ,
DOI : 10.1109/TC.1987.5009446
Parallelization, automatic, Encyclopedia of Parallel Programming, 2011. ,
Bounded Scheduling of Process Networks, 1995. ,
Hierarchical Task-Based Programming With StarSs, International Journal of High Performance Computing Applications, vol.23, issue.3, pp.284-299, 2009. ,
DOI : 10.1177/1094342009106195
A stream-computing extension to OpenMP, Proceedings of the 6th International Conference on High Performance and Embedded Architectures and Compilers, HiPEAC '11, pp.5-14, 2011. ,
DOI : 10.1145/1944862.1944867
URL : https://hal.archives-ouvertes.fr/hal-00659411
Control-driven data flow, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00717906
Work-streaming compilation of futures, 5th Workshop on Programming Language Approaches to Concurrency and Communication-cEntric Software (PLACES'12, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00786830
OpenStream, ACM Transactions on Architecture and Code Optimization, vol.9, issue.4, pp.1-25, 2013. ,
DOI : 10.1145/2400682.2400712
URL : https://hal.archives-ouvertes.fr/hal-00786675
An algorithmic approach to Schm??dgen's Positivstellensatz, Journal of Pure and Applied Algebra, vol.166, issue.3, pp.307-319, 2002. ,
DOI : 10.1016/S0022-4049(01)00041-X
A survey of stream processing, Acta Informatica, vol.34, issue.7, pp.491-541, 1997. ,
DOI : 10.1007/s002360050095
Polyhedral process networks, Handbook of Signal Processing Systems, pp.1335-1375, 2013. ,
Algorithms for weighted counting over parametric polytopes: A survey and a practical comparison, The 2008 International Conference on Information Theory and Statistical Learning, 2008. ,
Counting integer points in parametric polytopes using Barvinok rational functions, Algorithmica, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00534817
Array dataflow analysis for polyhedral X10 programs, 18th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPoPP'13), pp.23-34, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00761537
Checking race freedom of clocked X10 programs, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00907723
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
