Asymptotic study for Stokes-Brinkman model with jump embedded transmission conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2016
In this paper, one considers the coupling of a Brinkman model and Stokes equations with jump embedded transmission conditions. In this model, one assumes that the viscosity in the porous region is very small. Then we derive a Wentzel–Kramers–Brillouin (WKB) expansion in power series of the square root of this small parameter for the velocity and the pressure which are solution of the transmission problem. This WKB expansion is justified rigorously by proving uniform errors estimates.
StokesBrink.pdf (315.45 Ko) Télécharger le fichier
hal-01184429 , version 1 (14-08-2015)
Philippe Angot, Gilles Carbou, Victor Péron. Asymptotic study for Stokes-Brinkman model with jump embedded transmission conditions. Asymptotic Analysis, 2016, 96 (3-4), pp.223-249. ⟨10.3233/ASY-151336⟩. ⟨hal-01184429⟩
465 Consultations
307 Téléchargements
