Weight-biased leftist trees and modified skip lists, ACM J. Exp. Algorithmics, vol.3, 1998. ,
DOI : 10.1145/297096.297111
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.2962
Approximate counting: A detailed analysis, BIT, vol.21, issue.1, pp.113-134, 1985. ,
DOI : 10.1007/BF01934993
Mellin transforms and asymptotics: Finite differences and Rice's integrals, Theoretical Computer Science, vol.144, issue.1-2, pp.101-124, 1995. ,
DOI : 10.1016/0304-3975(94)00281-M
Analysis of an optimized search algorithm for skip lists, Theoretical Computer Science, vol.144, issue.1-2, pp.199-220, 1995. ,
DOI : 10.1016/0304-3975(94)00296-U
Approximate counting : an alternative approach, RAIRO - Theoretical Informatics and Applications, vol.25, issue.1, pp.43-48, 1991. ,
DOI : 10.1051/ita/1991250100431
Ein Ergebnis der Ordnungsstatistik mit Anwendung auf probabilistischs Z??hlen, Computing, vol.43, issue.1, pp.15-27, 1993. ,
DOI : 10.1007/BF02243826
The path length of random skip lists, Acta Informatica, vol.43, issue.42, pp.775-792, 1994. ,
DOI : 10.1007/BF01178735
Generalized approximate counting revisited, Theoretical Computer Science, vol.391, issue.1-2, 2006. ,
DOI : 10.1016/j.tcs.2007.10.035
URL : http://doi.org/10.1016/j.tcs.2007.10.035
Average search and update costs in skip lists, BIT, vol.33, issue.6, pp.316-332, 1992. ,
DOI : 10.1007/BF01994884
Skip lists: a probabilistic alternative to balanced trees, Communications of the ACM, vol.33, issue.6, pp.668-676, 1990. ,
DOI : 10.1145/78973.78977
Yet another application of a binomial recurrence, Order statistics. Computing, pp.401-410, 1990. ,
