Bipartite Random Graphs and Cuckoo Hashing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2006
The aim of this paper is to extend the analysis of Cuckoo Hashing of Devroye and Morin in 2003. In particular we make several asymptotic results much more precise. We show, that the probability that the construction of a hash table succeeds, is asymptotically $1-c(\varepsilon)/m+O(1/m^2)$ for some explicit $c(\varepsilon)$, where $m$ denotes the size of each of the two tables, $n=m(1- \varepsilon)$ is the number of keys and $\varepsilon \in (0,1)$. The analysis rests on a generating function approach to the so called Cuckoo Graph, a random bipartite graph. We apply a double saddle point method to obtain asymptotic results covering tree sizes, the number of cycles and the probability that no complex component occurs.
dmAG0133.pdf (140.4 Ko) Télécharger le fichier
hal-01184689 , version 1 (17-08-2015)
Reinhard Kutzelnigg. Bipartite Random Graphs and Cuckoo Hashing. Fourth Colloquium on Mathematics and Computer Science Algorithms, Trees, Combinatorics and Probabilities, 2006, Nancy, France. pp.403-406, ⟨10.46298/dmtcs.3486⟩. ⟨hal-01184689⟩
Collections
TDS-MACS
279 Consultations
1006 Téléchargements
