On the non-randomness of modular arithmetic progressions: a solution to a problem by V. I. Arnold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2006
We solve a problem by V. I. Arnold dealing with "how random" modular arithmetic progressions can be. After making precise how Arnold proposes to measure the randomness of a modular sequence, we show that this measure of randomness takes a simplified form in the case of arithmetic progressions. This simplified expression is then estimated using the methodology of dynamical analysis, which operates with tools coming from dynamical systems theory. In conclusion, this study shows that modular arithmetic progressions are far from behaving like purely random sequences, according to Arnold's definition.
dmAG0119.pdf (366.92 Ko) Télécharger le fichier
hal-01184715 , version 1 (17-08-2015)
Eda Cesaratto, Alain Plagne, Brigitte Vallée. On the non-randomness of modular arithmetic progressions: a solution to a problem by V. I. Arnold. Fourth Colloquium on Mathematics and Computer Science Algorithms, Trees, Combinatorics and Probabilities, 2006, Nancy, France. pp.271-288, ⟨10.46298/dmtcs.3510⟩. ⟨hal-01184715⟩
501 Consultations
505 Téléchargements
