The Size of the rth Smallest Component in Decomposable Structures with a Restricted Pattern - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2007
In our previous work [paper1], we derived an asymptotic expression for the probability that a random decomposable combinatorial structure of size n in the \exp -\log class has a given restricted pattern. In this paper, under similar conditions, we provide the probability that a random decomposable combinatorial structure has a given restricted pattern and the size of its rth smallest component is bigger than k, for r,k given integers. Our studies apply to labeled and unlabeled structures. We also give several concrete examples.
dmAH0128.pdf (279.24 Ko) Télécharger le fichier
hal-01184774 , version 1 (17-08-2015)
Lihua Dong, Zhicheng Gao, Daniel Panario. The Size of the rth Smallest Component in Decomposable Structures with a Restricted Pattern. 2007 Conference on Analysis of Algorithms, AofA 07, 2007, Juan les Pins, France. pp.403-422, ⟨10.46298/dmtcs.3526⟩. ⟨hal-01184774⟩
Collections
TDS-MACS
241 Consultations
526 Téléchargements
