A Spectral Technique for Coloring Random 3-Colorable Graphs, SIAM Journal on Computing, vol.26, issue.6, pp.1733-1748, 1997. ,
DOI : 10.1137/S0097539794270248
Finding a large hidden clique in a random graph, Random Structures and Algorithms, vol.13, pp.3-4457, 1998. ,
The chromatic number of random graphs, Combinatorica, vol.5, issue.1, pp.49-55, 1988. ,
DOI : 10.1007/BF02122551
Eigenvalues and graph bisection: An average-case analysis (extended abstract), Proc. 28th IEEE Symp. on Found. of Comp. Science, pp.280-285, 1987. ,
DOI : 10.1109/sfcs.1987.22
Constraint satisfaction by survey propagation, Computational Complexity and Statistical Physics, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00115530
Coloring bipartite hypergraphs, Integer Programming and Combinatorial Optimization, 5th International IPCO Conference, Proceedings, pp.345-358, 1996. ,
DOI : 10.1007/3-540-61310-2_26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.3498
Zero Knowledge and the Chromatic Number, Complexity 96?The Eleventh Annual IEEE Conference on Computational Complexity, pp.187-199, 1998. ,
DOI : 10.1006/jcss.1998.1587
Finding and certifying a large hidden clique in a semirandom graph, Random Structures and Algorithms, vol.25, issue.2, pp.195-208, 2000. ,
DOI : 10.1002/(SICI)1098-2418(200003)16:2<195::AID-RSA5>3.0.CO;2-A
Complete Convergence of Message Passing Algorithms for Some Satisfiability Problems, RANDOM, 2006. ,
DOI : 10.1007/11830924_32
Finding a Maximum Independent Set in a Sparse Random Graph, SIAM Journal on Discrete Mathematics, vol.22, issue.2, 2006. ,
DOI : 10.1137/060661090
A local search algorithm for 3SAT The Weizmann Institute of Science, 2004. ,
A spectral technique for random satisfiable 3CNF formulas, Proc. 14th ACM-SIAM Symp. on Discrete Algorithms, pp.357-363, 2003. ,
DOI : 10.1002/rsa.20213
Sharp thresholds of graph properties, and the k-sat problem, Journal of the American Mathematical Society, vol.12, issue.04, pp.1017-1054, 1999. ,
DOI : 10.1090/S0894-0347-99-00305-7
Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, pp.21-28, 1962. ,
DOI : 10.1109/TIT.1962.1057683
Expected behavior of graph coloring algorithms, Proc. Fundamentals of Computation Theory, pp.447-451, 1977. ,
DOI : 10.1007/3-540-08442-8_114
Analysis of Random Processes via And-Or Trees, Proc. 9th Symp. on Discrete Algorithms, 1998. ,
Analysis of low density parity check codes and improved designs using irregular graphs, Proceedings of the 30th ACM Symposium on Theory of Computing, pp.249-258, 1998. ,
Efficient erasure correcting codes, IEEE Transactions on Information Theory, vol.47, issue.2, pp.569-584, 2001. ,
DOI : 10.1109/18.910575
The chromatic number of random graphs, Combinatorica, vol.7, issue.1, pp.45-54, 1991. ,
DOI : 10.1007/BF01375472
Design of capacity-approaching irregular low-density parity-check codes, IEEE Transactions on Information Theory, vol.47, issue.2, pp.619-637, 2001. ,
DOI : 10.1109/18.910578
Probabilistic reasoning in intelligent systems: networks of plausible inference, 1988. ,
Expander codes, IEEE Transactions on Information Theory, vol.42, issue.6, pp.1710-1722, 1996. ,
DOI : 10.1109/18.556667
