Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Lattice reduction in two dimensions: analyses under realistic probabilistic models
Brigitte Vallée 1 Antonio Vera 1
1 Equipe AMACC - Laboratoire GREYC - UMR6072
GREYC - Groupe de Recherche en Informatique, Image et Instrumentation de Caen
Abstract : The Gaussian algorithm for lattice reduction in dimension 2 is precisely analysed under a class of realistic probabilistic models, which are of interest when applying the Gauss algorithm "inside'' the LLL algorithm. The proofs deal with the underlying dynamical systems and transfer operators. All the main parameters are studied: execution parameters which describe the behaviour of the algorithm itself as well as output parameters, which describe the geometry of reduced bases.
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01184797
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Monday, August 17, 2015 - 5:00:17 PM
Last modification on : Saturday, June 25, 2022 - 9:49:55 AM
Long-term archiving on: : Wednesday, November 18, 2015 - 12:18:26 PM
File
dmAH0114.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Brigitte Vallée, Antonio Vera. Lattice reduction in two dimensions: analyses under realistic probabilistic models. 2007 Conference on Analysis of Algorithms, AofA 07, 2007, Juan les Pins, France. pp.197-234, ⟨10.46298/dmtcs.3549⟩. ⟨hal-01184797⟩
Share
Metrics
Record views
184
Files downloads
556
