Enumeration of orientable coverings of a non-orientable manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
In this paper we solve the known V.A. Liskovets problem (1996) on the enumeration of orientable coverings over a non-orientable manifold with an arbitrary finitely generated fundamental group. As an application we obtain general formulas for the number of chiral and reflexible coverings over the manifold. As a further application, we count the chiral and reflexible maps and hypermaps on a closed orientable surface by the number of edges. Also, by this method the number of self-dual and Petri-dual maps can be determined. This will be done in forthcoming papers by authors.
dmAJ0119.pdf (129.51 Ko) Télécharger le fichier
hal-01185183 , version 1 (19-08-2015)
Jin Ho Kwak, Alexander Mednykh, Roman Nedela. Enumeration of orientable coverings of a non-orientable manifold. 20th Annual International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2008), 2008, Viña del Mar, Chile. pp.215-226, ⟨10.46298/dmtcs.3647⟩. ⟨hal-01185183⟩
Collections
TDS-MACS
54 Consultations
500 Téléchargements
