Analysis for pseudorandom number generators using logistic map, Proceedings of The 2006 International Symposium on Information Theory and its Applications, 2006. ,
A study on logistic map on integer for pseudorandom number generators, Proceedings of The 2008 Symposium on Cryptography and Information Security, 2008. ,
Les probabilit??s d??nombrables et leurs applications arithm??tiques, Rendiconti del Circolo Matematico di Palermo, vol.XXXIII, issue.1, pp.247-271, 1909. ,
DOI : 10.1007/BF03019651
Simply normal numbers to different bases, J. Univ. Comput. Sci, vol.8, pp.235-242, 2002. ,
On the simple normality to base 2 of the square root of s, for s not a perfect square. arXiv:math/0512404v2, 2005. ,
Uniform Distribution of Sequences, 1974. ,
Key generation scheme for broadcast encryption exploiting chaotic sequences, Proceedings of The 2005 Symposium on Cryptography and Information Security, 2005. ,
Some properties of logistic map on integral domains ,
On parameter choices for pseudorandom number generators based on integer-valued logistic map, Proceedings of The 31st Symposium on Information Theory and its Applications, 2008. ,
Logistic map: A possible random-number generator, Physical Review E, vol.51, issue.4, pp.3670-3678, 1995. ,
DOI : 10.1103/PhysRevE.51.3670
The logistic lattice in random number generation, Proceedings of the 30th Annual Allerton Conference on Communications, Control, and Computing, pp.922-931, 1993. ,
