HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
TrustedMR: A Trusted MapReduce System based on Tamper Resistance Hardware
Quoc-Cuong To 1, 2 Benjamin Nguyen 2, 3 Philippe Pucheral 2, 1
2 SMIS - Secured and Mobile Information Systems
PRISM - Parallélisme, Réseaux, Systèmes, Modélisation, UVSQ - Université de Versailles Saint-Quentin-en-Yvelines, Inria Paris-Rocquencourt, CNRS - Centre National de la Recherche Scientifique : UMR8144
Abstract : With scalability, fault tolerance, ease of programming, and flexibility , MapReduce has gained many attractions for large-scale data processing. However, despite its merits, MapReduce does not focus on the problem of data privacy, especially when processing sensitive data, such as personal data, on un-trusted infrastructure. In this paper, we investigate a scenario based on the Trusted Cells paradigm : a user stores his personal data in a local secure data store and wants to process this data using MapReduce on a third party infrastructure , on which secure devices are also connected. The main contribution of the paper is to present TrustedMR, a trusted MapReduce system with high security assurance provided by tamper-resistant hardware, to enforce the security aspect of the MapReduce. Thanks to TrustedMR, encrypted data can then be processed by untrusted computing nodes without any modification to the existing MapReduce framework and code. Our evaluation shows that the performance overhead of TrustedMR is limited to few percents, compared to an original MapReduce framework that handles cleartexts.
Document type :
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01185484
Contributor : Quoc-Cuong To Connect in order to contact the contributor
Submitted on : Tuesday, September 1, 2015 - 9:50:58 AM
Last modification on : Friday, January 21, 2022 - 3:18:27 AM
Long-term archiving on: : Wednesday, December 2, 2015 - 10:19:34 AM
File
cr.pdf
Identifiers
  • HAL Id : hal-01185484, version 2
Collections
Citation
Quoc-Cuong To, Benjamin Nguyen, Philippe Pucheral. TrustedMR: A Trusted MapReduce System based on Tamper Resistance Hardware. 2015. ⟨hal-01185484v2⟩
Share
Metrics
Record views
191
Files downloads
304
