Poisson approximation and the Chen-Stein method, Stat. Sci, vol.5, issue.4, pp.403-424, 1990. ,
Markov renewal processes, counters and repeated sequences in Markov chains, Advances in Applied Probability, vol.35, issue.03, pp.521-545, 1987. ,
DOI : 10.1080/01621459.1983.10477947
Poisson Approximation, 1992. ,
The Distribution of Subword Counts is Usually Normal, European Journal of Combinatorics, vol.14, issue.4, pp.265-275, 1993. ,
DOI : 10.1006/eujc.1993.1030
Approximating Markov chain occupancy distributions, 2010. ,
Perfect sampling of ergodic Harris chains, The Annals of Applied Probability, vol.11, issue.2, pp.438-451, 2001. ,
DOI : 10.1214/aoap/1015345299
Central limit theorem for nonstationary Markov chains. I. Theory Probab, Appl, vol.1, issue.1, pp.65-79, 1956. ,
Central limit theorem for nonstationary Markov chains. II. Theory Probab, Appl, vol.1, issue.4, pp.329-383, 1956. ,
Le cas discontinu des probabilités en cha??necha??ne, Publ. Fac. Sci. Univ. Masaryk (Brno), vol.236, pp.1-13, 1937. ,
Exposé de la theorie des cha??nescha??nes simple constantes de MarkovàMarkov`Markovà un nombre fini d'´ etats, Rev. Math. Union Interbalkan, vol.2, pp.77-105, 1938. ,
Essentials of stochastic processes, 1999. ,
Compound Poisson approximation for Markov chains using Stein's method ,
An Introduction to Probability Theory and Its Applications, 1968. ,
The occurrence of sequence patterns in repeated experiments and hitting times in a Markov chain, Stochastic Processes and their Applications, vol.11, issue.1, pp.101-108, 1981. ,
DOI : 10.1016/0304-4149(81)90025-9
Uniform coupling of non-homogeneous Markov chains, J. Appl. Probab, vol.12, issue.4, pp.753-762, 1975. ,
Weak ergodicity in nonhomogeneous Markov chains, Proc. Cambridge, pp.233-246, 1958. ,
On two recent papers on ergodicity in nonhomogeneous Markov chains, Ann. Math. Statist, vol.43, issue.5, pp.1732-1736, 1972. ,
Natural and artificial RNAs occupy the same restricted region of sequence space, RNA, vol.16, issue.2, pp.280-289, 2010. ,
Information, probability, and the abundance of the simplest RNA active sites, Front. Biosci, vol.13, pp.6060-71, 2008. ,
Mixing for Markov operators, Zeitschrift f???r Wahrscheinlichkeitstheorie und Verwandte Gebiete, vol.16, issue.3, pp.231-242, 1971. ,
DOI : 10.1007/BF00534111
A probabilistic proof of Blackwell's renewal theorem, Ann. Probab, vol.5, issue.3, pp.482-485, 1977. ,
Minimal Markov chain embeddings of pattern problems, Proceedings of the 2007 Information Theory and Applications Workshop, 2007. ,
Markovian embeddings of general random strings, Proceedings of the Fifth Workshop on Analytic Algorithmics and Combinatorics, pp.183-190, 2008. ,
Extension of the law of large numbers to dependent quantities ,
Exact sampling from a continuous state space. Scand, J. Stat, vol.25, issue.3, pp.483-502, 1998. ,
Perfect simulation of conditionally specified models, J. R. Statist. Soc. B, vol.61, issue.1, pp.251-264, 1999. ,
Regexpcount, a symbolic package for counting problems on regular expressions and words, Fund. Inform, vol.56, issue.12, pp.71-88, 2003. ,
Motif statistics, Theoretical Computer Science, vol.287, issue.2, pp.593-617, 2002. ,
DOI : 10.1016/S0304-3975(01)00264-X
Ergodic Theorems for Infinite Probabilistic Tables, The Annals of Mathematical Statistics, vol.41, issue.2, pp.539-550, 1970. ,
DOI : 10.1214/aoms/1177697094
Uniform rates of convergence for Markov chain transition probabilities, Z. Wahrscheinlichkeitstheorie und Verw. Gebiete, vol.29, pp.193-227, 1974. ,
Improved compound Poisson approximation for the number of occurrences of any rare word family in a stationary Markov chain, Adv. in Appl. Probab, vol.39, issue.1, pp.128-140, 2007. ,
Non-negative matrices, 1973. ,
On the historical development of the theory of finite inhomogeneous Markov chains, Proc. Cambridge Philos. Soc, pp.507-513, 1973. ,
Applications of ergodicity coefficients to homogeneous Markov chains In Doeblin and modern probability, Contemp. Math Amer. Math. Soc, vol.149, pp.189-199, 1993. ,
The classical coupling, a refinement, Teor. Veroyatnost. i Primenen, vol.35, issue.4, pp.809-817, 1990. ,
