Conference papers
Finding hidden cliques in linear time
Abstract : In the hidden clique problem, one needs to find the maximum clique in an $n$-vertex graph that has a clique of size $k$ but is otherwise random. An algorithm of Alon, Krivelevich and Sudakov that is based on spectral techniques is known to solve this problem (with high probability over the random choice of input graph) when $k \geq c \sqrt{n}$ for a sufficiently large constant $c$. In this manuscript we present a new algorithm for finding hidden cliques. It too provably works when $k > c \sqrt{n}$ for a sufficiently large constant $c$. However, our algorithm has the advantage of being much simpler (no use of spectral techniques), running faster (linear time), and experiments show that the leading constant $c$ is smaller than in the spectral approach. We also present linear time algorithms that experimentally find even smaller hidden cliques, though it remains open whether any of these algorithms finds hidden cliques of size $o(\sqrt{n})$.
Complete list of metadata
https://hal.inria.fr/hal-01185601
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Thursday, August 20, 2015 - 4:34:03 PM
Last modification on : Thursday, October 15, 2020 - 2:42:03 PM
Long-term archiving on: : Wednesday, April 26, 2017 - 10:12:38 AM
File
dmAM0114.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Uriel Feige, Dorit Ron. Finding hidden cliques in linear time. 21st International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'10), 2010, Vienna, Austria. pp.189-204, ⟨10.46298/dmtcs.2802⟩. ⟨hal-01185601⟩
Share
Metrics
Record views
192
Files downloads
1243
