Model Checking Linear Programs with Arrays, Proceedings of the Workshop on Software Model Checking, pp.79-94, 2006. ,
DOI : 10.1016/j.entcs.2006.01.006
A Generic Framework for Symbolic Execution, 6th International Conference on Software Language Engineering, pp.281-301, 2013. ,
DOI : 10.1007/978-3-319-02654-1_16
URL : https://hal.archives-ouvertes.fr/hal-00853588
Towards a <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi mathvariant="double-struck">K</mml:mi></mml:math> Semantics for OCL, Proceedings of the Second International Workshop on the K Framework and its Applications, pp.81-96, 2011. ,
DOI : 10.1016/j.entcs.2014.05.004
Language Definitions as Rewrite Theories, Proceedings of the 10th International Workshop on Rewriting Logic and its Applications (WRLA'14), pp.97-112, 2014. ,
DOI : 10.1007/978-3-319-12904-4_5
URL : https://hal.archives-ouvertes.fr/hal-00950775
Term rewriting and all that, 1998. ,
Symbolic Execution with Separation Logic, APLAS, pp.52-68, 2005. ,
DOI : 10.1007/11575467_5
A Complete Semantics of Java, Proceedings of the 42nd Symposium on Principles of Programming Languages (POPL'15, 2015. ,
EXE: automatically generating inputs of death, ACM Conference on Computer and Communications Security, pp.322-335, 2006. ,
All About Maude, A High-Performance Logical Framework, LNCS, vol.4350, 2007. ,
Parameterized Unit Testing with Pex, Lecture Notes in Computer Science, vol.4966, pp.171-181, 2008. ,
DOI : 10.1007/978-3-540-79124-9_12
Z3: An Efficient SMT Solver, Lecture Notes in Computer Science, vol.4963, pp.337-340, 2008. ,
DOI : 10.1007/978-3-540-78800-3_24
Verifying general safety properties of Ada tasking programs, IEEE Transactions on Software Engineering, vol.16, issue.1, pp.51-63, 1990. ,
DOI : 10.1109/32.44363
An executable formal semantics of C with applications, ACM SIGPLAN Notices, vol.47, issue.1, pp.533-544, 2012. ,
DOI : 10.1145/2103621.2103719
Variant Narrowing and Equational Unification, Electronic Notes in Theoretical Computer Science, vol.238, issue.3, pp.103-119, 2009. ,
DOI : 10.1016/j.entcs.2009.05.015
URL : http://doi.org/10.1016/j.entcs.2009.05.015
An Executable Formal Semantics of PHP, Proceedings of European Conference on Object-Oriented Programming, 2014. ,
DOI : 10.1007/978-3-662-44202-9_23
DART: directed automated random testing, PLDI, pp.213-223, 2005. ,
KOOL: An Application of Rewriting Logic to Language Prototyping and Analysis, RTA, pp.246-256, 2007. ,
DOI : 10.1007/978-3-540-73449-9_19
Generalized Symbolic Execution for Model Checking and Testing, TACAS, pp.553-568, 2003. ,
DOI : 10.1007/3-540-36577-X_40
Symbolic execution and program testing, Communications of the ACM, vol.19, issue.7, pp.385-394, 1976. ,
DOI : 10.1145/360248.360252
KLOVER: A Symbolic Execution and Automatic Test Generation Tool for C++ Programs, Lecture Notes in Computer Science, vol.6806, pp.609-615, 2011. ,
DOI : 10.1007/978-3-642-00768-2_27
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.205.5180
Verifying reachabilitylogic properties on rewriting-logic specifications. Logic, Rewriting, and Concurrency -Festschrift Symposium in Honor of José Meseguer, to appear . Also available as a technical report http ,
DOI : 10.1007/978-3-319-23165-5_21
URL : https://hal.archives-ouvertes.fr/hal-01158941
$\mathbb{K}$ Framework Distilled, 9th International Workshop on Rewriting Logic and its Applications, pp.31-53, 2012. ,
DOI : 10.1007/978-3-642-34005-5_3
Symbolic reachability analysis using narrowing and its application to verification of cryptographic protocols, Higher-Order and Symbolic Computation, pp.123-160, 2007. ,
Verification of Java Programs Using Symbolic Execution and Invariant Generation, Lecture Notes in Computer Science, vol.2989, pp.164-181, 2004. ,
DOI : 10.1007/978-3-540-24732-6_13
A survey of new trends in symbolic execution for software testing and analysis, International Journal on Software Tools for Technology Transfer, vol.17, issue.2, pp.339-353, 2009. ,
DOI : 10.1007/s10009-009-0118-1
Rewriting Modulo SMT and Open System Analysis, Lecture Notes in Computer Science, vol.8663, pp.247-262, 2014. ,
DOI : 10.1007/978-3-319-12904-4_14
URL : http://hdl.handle.net/2060/20150014338
One-path reachability logic, Proceedings of the 28th Symposium on Logic in Computer Science (LICS'13), pp.358-367, 2013. ,
An overview of the K semantic framework, The Journal of Logic and Algebraic Programming, vol.79, issue.6, pp.397-434, 2010. ,
DOI : 10.1016/j.jlap.2010.03.012
Checking reachability using matching logic, OOPSLA, pp.555-574, 2012. ,
From Hoare Logic to Matching Logic Reachability, Proceedings of the 18th International Symposium on Formal Methods (FM'12), pp.387-402, 2012. ,
DOI : 10.1007/978-3-642-32759-9_32
Foundations of Algebraic Specification and Formal Software Development. Monographs in Theoretical Computer Science . An EATCS Series, 2012. ,
Inferring invariants by symbolic execution, Proceedings of 4th International Verification Workshop (VERIFY'07), 2007. ,
CUTE: a concolic unit testing engine for C, Proceedings of the 10th European software engineering conference held jointly with 13th ACM SIGSOFT international symposium on Foundations of software engineering, pp.263-272, 2005. ,
A rewriting logic approach to operational semantics, Information and Computation, vol.207, issue.2, pp.305-340, 2009. ,
DOI : 10.1016/j.ic.2008.03.026
Using model checking with symbolic execution to verify parallel numerical programs, Proceedings of the 2006 international symposium on Software testing and analysis , ISSTA'06, pp.157-168, 2006. ,
DOI : 10.1145/1146238.1146256
Parallel symbolic execution for structural test generation, Proceedings of the 19th international symposium on Software testing and analysis, ISSTA '10, pp.183-194, 2010. ,
DOI : 10.1145/1831708.1831732
