New interface
Journal articles
Isotopic Approximation within a Tolerance Volume
Manish Mandad 1 David Cohen-Steiner 2 Pierre Alliez 1
1 TITANE - Geometric Modeling of 3D Environments
CRISAM - Inria Sophia Antipolis - Méditerranée
2 DATASHAPE - Understanding the Shape of Data
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Saclay - Ile de France
Abstract : We introduce in this paper an algorithm that generates from an input tolerance volume a surface triangle mesh guaranteed to be within the tolerance, intersection free and topologically correct. A pliant meshing algorithm is used to capture the topology and discover the anisotropy in the input tolerance volume in order to generate a concise output. We first refine a 3D Delaunay triangulation over the tolerance volume while maintaining a piecewise-linear function on this triangulation, until an isosurface of this function matches the topology sought after. We then embed the isosurface into the 3D triangulation via mutual tessellation, and simplify it while preserving the topology. Our approach extends to surfaces with boundaries and to non-manifold surfaces. We demonstrate the versatility and efficacy of our approach on a variety of data sets and tolerance volumes.
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01186074
Contributor : Pierre Alliez Connect in order to contact the contributor
Submitted on : Friday, October 14, 2016 - 8:26:32 PM
Last modification on : Saturday, June 25, 2022 - 11:23:50 PM
File
approximation.pdf
Identifiers
Citation
Manish Mandad, David Cohen-Steiner, Pierre Alliez. Isotopic Approximation within a Tolerance Volume. ACM Transactions on Graphics, 2015, Proceedings of SIGGRAPH, 34 (4), pp.12. ⟨10.1145/2766950⟩. ⟨hal-01186074v2⟩
Share
Metrics
Record views
1135
Files downloads
749
