An obvious proof of Fishburn's interval order theorem, Discrete Mathematics, vol.118, issue.1-3, pp.3-239, 1993. ,
DOI : 10.1016/0012-365X(93)90065-2
<mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn mathvariant="bold">2</mml:mn><mml:mo>+</mml:mo><mml:mn mathvariant="bold">2</mml:mn><mml:mo stretchy="false">)</mml:mo></mml:math>-free posets, ascent sequences and pattern avoiding permutations, Journal of Combinatorial Theory, Series A, vol.117, issue.7, pp.884-909, 2010. ,
DOI : 10.1016/j.jcta.2009.12.007
Crossings and nestings of matchings and partitions, Transactions of the American Mathematical Society, vol.359, issue.04, pp.359-1555, 2007. ,
DOI : 10.1090/S0002-9947-06-04210-3
Moments des q-Polyn??mes de Laguerre et la Bijection de Foata-Zeilberger, Advances in Applied Mathematics, vol.15, issue.3, pp.262-304, 1994. ,
DOI : 10.1006/aama.1994.1010
Couplage et Pfaffiens en combinatoire, physique et informatique, Thèse du 3me cycle, 1983. ,
Ascent sequences and upper triangular matrices containing non-negative integers, Electronic Journal of Combinatorics, vol.17, issue.116pp, p.53, 2010. ,
Interval graphs and interval orders, Discrete Mathematics, vol.55, issue.2, 1985. ,
DOI : 10.1016/0012-365X(85)90042-1
URL : http://doi.org/10.1016/0012-365x(85)90042-1
Intransitive Indifference in Preference Theory: A Survey, Operations Research, vol.18, issue.2, pp.207-208, 1970. ,
DOI : 10.1287/opre.18.2.207
Intransitive indifference with unequal indifference intervals, Journal of Mathematical Psychology, vol.7, issue.1, pp.144-149, 1970. ,
DOI : 10.1016/0022-2496(70)90062-3
Distribution of crossings, nestings and alignments of two edges in matchings and partitions, Electronic Journal of Combinatorics, vol.13, issue.12, p.pp, 2006. ,
The Encyclopedia of Integer Sequences Electronic version available at www, 1995. ,
ENUMERATION OF CHORD DIAGRAMS AND AN UPPER BOUND FOR VASSILIEV INVARIANTS, Journal of Knot Theory and Its Ramifications, vol.07, issue.01, pp.93-114, 1998. ,
DOI : 10.1142/S0218216598000073
On the Enumeration of Decision Patterns Involving $n$ Means, The Annals of Mathematical Statistics, vol.28, issue.1, pp.256-259, 1957. ,
DOI : 10.1214/aoms/1177707051
Vassiliev invariants and a strange identity related to the Dedeking eta-function, Topology, pp.40-945, 2001. ,
