A Certainty-Based Model for Uncertain Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Fuzzy Systems Année : 2015
This paper considers relational databases containing uncertain attribute values when some knowledge is available about the more or less certain value (or disjunction of values) that a given attribute in a tuple may take. We propose a possibility-theory-based model suited to this context and extend the operators of relational algebra to handle such relations in a “compact,” thus efficient, way. It is shown that the model is a representation system for the whole relational algebra. An important result is that the data complexity associated with the extended operators in this context is the same as in the classical database case, which makes the approach highly scalable.
hal-01186506 , version 1 (25-08-2015)
Olivier Pivert, Henri Prade. A Certainty-Based Model for Uncertain Databases. IEEE Transactions on Fuzzy Systems, 2015, 23 (4), pp.1181 - 1196. ⟨10.1109/TFUZZ.2014.2347994⟩. ⟨hal-01186506⟩
178 Consultations
0 Téléchargements
